Author Topic: Can't reverse source code in the trail version  (Read 2271 times)
DontBugMe
« on: October 25, 2011, 09:37:04 pm »
1. I am testing the product but I cant use the how to reverse engineering my c# projects.
the menus under Element-> Source code  engineer is all disabled, how do i import c# projects or solution?
2. I have 3 projects and they are depended one on each other, is it possible to see 3 of them on a single board?
Re: Can't reverse source code in the trail version
« Reply #1 on: October 26, 2011, 07:37:15 pm »
I think you can choose when starting which type of EA you want to run when using a trial version.
Source code engineering is only available in some type of EA packages.
You can have multiple projects in one repository.
