Author Topic: Synchronize with code: How to specify filename?  (Read 4522 times)
Asperamanca
« on: November 09, 2011, 02:20:09 am »
I want to synchronize a class I have originally generated with EA. However, I have since changed the filename.
How do I update the filename in EA, so synchronization works again?
Aaron B
Re: Synchronize with code: How to specify filename
« Reply #1 on: November 09, 2011, 09:05:04 am »
You can find the filename currently associated with a Class in EA using the Properties window.  (View | Element Properties)
Edit the filename property to match the path of the file you want to synchronize.
Asperamanca
« Reply #2 on: November 09, 2011, 06:44:54 pm »
I had already gone through the property dialogue, but had not been able to find the existing (incorrect) filename anywhere.
(EA 9.1)
Can you give me a hint where to look?
Aaron B
« Reply #3 on: November 10, 2011, 09:28:05 am »
It's in the docked Properties window, not the properties dialog.
From the main menu select - View | Element Properties, or press Alt+1.
Asperamanca
« Reply #4 on: November 10, 2011, 06:12:13 pm »
Yes! Thanks!
Now, is there a way to do a search-and-replace on the Filenames?
« Reply #5 on: November 10, 2011, 06:32:34 pm »
Probably not.
Options are:
- Write a script to search/replace filenames using the API
- Execute an SQL update statement on the database to update the filenames
- Export to XMI, find/replace in a text editor, and import again.
Asperamanca
« Reply #6 on: November 10, 2011, 06:37:10 pm »
Solved it, using XMI export and import.
I am sure there are cooler ways to do it, but it worked.
