Author Topic: Import multiple packages using XMI  (Read 2852 times)
S. MAINIL
« on: November 10, 2011, 12:57:59 am »
Hi all,
I am testing EA and I am facing a problem.
Our users are currently using an other UML tools. They export me their packages in one single XMI file.
But when I import it in EA, only the first package is created.
Is there a way to import the whole packages contained in the XMI file?
Thanks for your help
Re: Import multiple packages using XMI
« Reply #1 on: November 10, 2011, 05:14:28 pm »
Just make sure you also export the owning package of all those packages.
If your xmi file contains
package Root
  package A
  package B
I'm sure that will be imported just fine.
I can imagine EA having troubles trying to import an xmi file that has multiple "root" packages. (not sure what the xmi standard says about that)
« Last Edit: November 10, 2011, 05:14:47 pm by Geert.Bellekens »
S. MAINIL
« Reply #2 on: November 10, 2011, 10:08:25 pm »
I created a root package, owner of all of my packages and the import worked fine.
Thanks for your help Geert.
