Author Topic: Information on testing the trial version: ERROR  (Read 3416 times)
Dejota
« on: October 21, 2011, 12:41:40 am »
When i tried to test the interaction with my database on project browser -> database engineering i right clicked and went to Code Engineering -> Import schema from DB ODBC
When I tried to enter the path of my server the system tells me: "Unable To Obtain Table Information" and I'm not able to type or navigate to find my server options.
I tried it for Tools -> Database Engineering -> Import schema from DB ODBC and the same thing happened.
Information: I'm running the Professional trial version on WINE on an Ubuntu 10.10 distribution.
Any clue?
bas
Re: Information on testing the trial version: ERRO
« Reply #1 on: November 09, 2011, 10:55:53 pm »
Hi gays,
I have the same problem. When I try to choose odbs name at Import DB schema EA shows error "Unable To Obtain Table Information".
EA v. 8.0.860
MySql v. 5.0.77
MySql ODBC 5.1 Driver
bas
« Reply #2 on: November 10, 2011, 11:52:27 pm »
Pls help. What did I do wrong? Why can this error happen?
« Last Edit: November 11, 2011, 12:21:32 am by bas »
Sunshine
  • Its the results that count
« Reply #3 on: November 11, 2011, 01:08:21 pm »
Shot in the dark here as I haven't used EA  on Wine under ubuntu and also not sure what data base Dejota is using. However I do recall a colleague having similar problems a few years back because the log on ID didn't have privileges to read the schema data. The solution was he changed his logon ID to have full admin privileges on the database.
Hope that helps  :)
Happy to help
Dejota
« Reply #4 on: November 12, 2011, 03:35:23 am »
This is the answer I got from sparx folks, it helped a lot.
I hope it can help all of you as well
You  would need to check that the steps covered on the link below have been followed :
http://www.sparxsystems.com/support/faq/enterprise-architect-WINE.html#two
 as well as, set up the correct ODBC connectors to your DBMS under Wine using the MDAC ODBC driver.
If that is complete and you still have problems we would need more detail on the DBMS being configured and the errors being returned.
I hope this is of help.
Best regards,
Dermot O’Bryan
Sparx Systems Pty Ltd
