Author Topic: Changing Diagram and Element Types  (Read 3698 times)
John Kendall
« on: October 08, 2011, 01:20:41 am »
Why can't I change the type of elements to Part and why can't I change the type of any Sequence diagrams - even to other types of sequence diagrams?
thanks
John
John Kendall
Re: Changing Diagram and Element Types
« Reply #1 on: November 15, 2011, 03:59:08 am »
Any clues on this one? Thanks
« Reply #2 on: November 15, 2011, 06:16:09 am »
You can't change it to be part since there is no dialogue to tell which part it shall be from. You would need to raise a feature request here.
Regarding the sequence: you should be more specific on what you want to change.
« Last Edit: November 15, 2011, 06:16:39 am by qwerty »
« Reply #3 on: November 15, 2011, 05:26:53 pm »
See menu options:
Element|Advanced|Change Type...
Diagram|Advanced|Change Type
These options are only available from the main menu, not from the context menu.
John Kendall
« Reply #4 on: November 22, 2011, 12:55:18 am »
Geert, The point is that you cant change the type of an element from/to a part. Or change the type of a sequence diagram.  I have a number of different sequence diagram types in my Profile I need to be able to change from one to another when users choose the wrong one.  At present it is not possible to do this.
« Reply #5 on: November 22, 2011, 01:21:54 am »
If its not allowed then you'll have to issue a change request.
If you really really need this fast you could try to change the type using the api or even a simple sql update statement. In this case thorough testing is recommended.
