Author Topic: Oracle Designer V10.x to Sparx Enteprise Architect  (Read 4738 times)
Sunshine
  • Its the results that count
« on: November 24, 2011, 09:45:31 am »
Has anyone successfully transferred data from an respository in Oracle Designer 10.x to a Sparx EA respository. If so what mechanism did you find worked best.
Happy to help
Sunshine
Re: Oracle Designer V10.x to Sparx Enteprise Archi
« Reply #1 on: November 29, 2011, 06:54:49 am »
After doing some investigation it seems we have the following options.
a) Export to SAS using a meta bridge then import into Sparx EA.
b) Generated the databases with Oracle designer and reverse engineer the databases.
Happy to help
praba
Reverse Engineer an Oracle schema
« Reply #2 on: December 04, 2011, 08:18:40 am »
EA version - 7.5
Oracle version - Oracle 9i
I am completely new to EA and I am trying to reverse engineer an Oracle schema. I want to have Data Model, and furhter information from the schema to document it and use the information for to design same kind of schema.
I am able to install and when I try to Import Database Schema, I was thrown an error 'Invalid data source..check configuration', but I was able to create system DSN and the connection test was pass.
Kidly help!
Praba
