Author Topic: Diagram properties preset  (Read 4309 times)
st33ve
« on: December 08, 2011, 12:33:13 am »
On doagram properties page I can check "Use Alias If Available". Can I specify initial value of the attribute for newly created diagrams?
I want all diagrams to display alias by default, without need to open property dialog and set the property manually.
Am I overlooking some setting?
Thanks for answer.
st33v3
Re: Diagram properties preset
« Reply #1 on: December 08, 2011, 04:34:07 am »
You need to do that via automation.
« Reply #2 on: December 08, 2011, 06:34:23 pm »
Have you tried the template package?
Often that helps for those settings that you can't set in Tools|Options
« Last Edit: December 08, 2011, 06:34:38 pm by Geert.Bellekens »
st33ve
« Reply #3 on: December 08, 2011, 08:35:05 pm »
Automation is something I would rather not use.
Template package is what I wanted. Thank you. Some ways in EA are really not straight forward.
St33ve
« Reply #4 on: December 09, 2011, 08:40:20 am »
I thought you were looking for changing a couple of existing diagrams. That's why I suggested automation. But obviously Geerts way is what you were looking for.
