Author Topic: build debug script format  (Read 4192 times)
tecman
« on: December 12, 2011, 09:54:17 am »
I'm trying to use EA for the first time to generate a sequence diagram from running my .net c# solution (with 4 projects).
What should the build & debug script commands should look like to build all 4 projects? I've tried:
"C:\Program Files\Microsoft Visual Studio 10.0\Common7\IDE\devenv.exe" /Build Debug CT_Contacts_Manager.sln
but it just returns "Build Manager completed with exit code 1"
Is there a way I can see the required syntax  by looking at the build command VS2010 uses?
thanks!
