Author Topic: Remove a model from Version Control  (Read 4604 times)
Stefan Bolleininger
« on: December 08, 2011, 12:35:46 am »
within my work with ea i made a little mistake and have a small problem now.
I checked a complete model into version control, but this model should not be controlled.
Is there a possibility to uncheck this model within just a few clicks? I could take out every package, but this could take hours.
It there any suggestion?
Thank you!
Re: Remove a model from Version Control
« Reply #1 on: December 08, 2011, 04:37:02 am »
Two ways: a) squeeze the database. b) export and edit xmi and then re-import. a) is fast if you know the db structure. b) takes longer but can be done with a good editor (notepad++) with not too much effort.
« Reply #2 on: December 08, 2011, 06:26:36 pm »
select * from t_package p
where p.PackageFlags like '%VCCFG=%'
will get you all packages under version control.
abruckner
« Reply #3 on: December 14, 2011, 08:12:42 pm »
other way was to use the free tool "EnarSpy" from here:
https://blog.lieberlieber.com/2011/09/22/enar-spy-update/
installs as a EA-plugin, you open your model, then choose from extensions-menĂ¼: "EnarSpy\Traces\Remove version control".
This does all the removing in one click.
