Author Topic: About Classifier ":"  (Read 4387 times)
pha
« on: December 19, 2011, 07:42:37 pm »
Hi.
How can I clean this "name:" at dragging from Project Browser?
IAT.
Re: About Classifier ":"
« Reply #1 on: December 19, 2011, 07:51:37 pm »
You can't. If you don't want this then don't use nested classes.
Niy
« Reply #2 on: December 20, 2011, 02:50:52 am »
It's not a bug, it's a feature :D
solution:
1:you could only link the class2 into the class1s-diagram and keep class 2 in the package1 (yah, solves the problem, but readability...)
so here is the real solution:
2:Set Diagram > Properties > Diagram > "Use Alias if Avaible" to True and set an alias for Class2.
Problem solved :)
philchudley
« Reply #3 on: December 22, 2011, 08:07:13 am »
Hi All
You can turn this parent class:: notation off for all class diagrams by using
Tools | Options | Diagrams and then checking "Disable fully scoped object names"
Set this option and you should see the Class1:: disappear
Cheers
Phil
Models are great!
pha
« Reply #4 on: December 22, 2011, 10:43:39 am »
Great! Thank you!
