Author Topic: Filter speciffic tagged value in generated rtf doc  (Read 3128 times)
shirleyj
« on: December 29, 2011, 07:32:55 pm »
I want to generate a rtf doc that will show me only specific tagged value from a list of many tags that are included in elements.
i tried using the filters in the doc. generator but failed to filter the tags.
i also tried building sql search to do the same but the same result..
any ideas?
tnx in advance,
Shirley
philchudley
Re: Filter speciffic tagged value in generated rtf
« Reply #1 on: December 29, 2011, 10:46:55 pm »
Hi Shirley
Using the Element checkbox, right-click and insert a data field valueOf
You will then be prompted for a tagged value name, (you will have to remember this and type it correctly), upon output the current value of the tagged value will be output.
Repeat this process for as may tagged values as you wish
Simple example:
[highlight]element>[/highlight]
{Element.valueOf(myTag)}
[highlight]<element
[/highlight]
Where myTag is the name of your selected tagged value
Cheers
Phil
Models are great!
shirleyj
« Reply #2 on: January 01, 2012, 05:31:39 pm »
Tnx, ill try that!
Shirley
