Author Topic: HTML output via model documents  (Read 4596 times)
OpenIT Solutions
« on: December 23, 2011, 03:02:07 am »
Hi All,
Has anyone else observed this behaviour....any diagrams or elements (other than packages) in the package that i add as an attribute to my "model document" class are not included in the html output..?
Is this by design? Or have i done something wrong ? Or is this a bug ?
Jon.
Re: HTML output via model documents
« Reply #1 on: December 23, 2011, 10:49:52 am »
It's only intended to be for Packages. Although you can specify a search instead.
OpenIT Solutions
« Reply #2 on: December 23, 2011, 09:12:46 pm »
To be clear i've added a package as an attribute at the packages root it has a diagram and associated elements. These are not included in the html output only sub packages and their content.....this doesn't seem right to me....if i right click on the package explictly and select documentation -> html ... all is well the output include the diagram and elements....its just the model document html output that doesn't ! Is this by design ? A known issue ?
Also you mention a search for html output .... this would be great .... have i understood correctly? If so how do you apply a search to html output for a model document? Just add to the search tag value ?
Jon.
OpenIT Solutions
« Reply #3 on: January 05, 2012, 12:14:25 am »
Any update on this one Simon - should i report as a bug?
« Reply #4 on: January 05, 2012, 09:21:43 am »
I'm not sure what you are describing, you'll have to contact support.
