Author Topic: UML2.0 Implemented Metamodel  (Read 3617 times)
ddinh
« on: January 05, 2012, 09:43:47 pm »
Could you please provide the metamodel of your UML2.0 implementation please ?
My objective is to list the activities performed by an instantiated actor.
For doing this, I instantiated an actor through "instance classifier" command (contextual menu of an swim lane or pool). Then I tried to build a matrix between Activity & Activity Partition but I'm not able to find the kind of relationship between both concepts.
In the model browser, activities are contained within a activity partition but when you display the properties of the activity partition, related links is empty...
Do you have any clue on this ?
Thanks in advance,
Dorian.
Re: UML2.0 Implemented Metamodel
« Reply #1 on: January 05, 2012, 09:57:24 pm »
The relation is the containment. When an element is placed inside another it has a parent-relation which can be seen in the GUI by inspecting the browser. In automation you have a ParentID.
« Reply #2 on: January 05, 2012, 11:19:16 pm »
Yes, unfortunately EA doesn't add nesting relations for owned elements.
ddinh
« Reply #3 on: January 05, 2012, 11:57:02 pm »
@qwerty.
When editing a matrix :
Source : ActivityPartition
Target : Activity
Direction : Source->Target
What should be the link type ? "nesting", "aggregation", "composition" don't work. There is no "containment" type unfortunately...
« Reply #4 on: January 06, 2012, 02:04:55 am »
Hmm. I don't know whether it's a good idea at all to create a relation. Once you done that (you can always create a dependency) this will appear in the diagram. And that's probably not what you want. So the answer to your question is: don't use the matrix. Try a different approach.
