Author Topic: RTF Documentation: add single Diagram  (Read 2658 times)
Niy
« on: January 10, 2012, 07:41:59 pm »
Hi folks,
hope you can help me.
I want to add a single diagram into my documentation, I tried some ways, but none worked.
best way so far: create custom search that returns only the diagram, but as soon as I create a model document and add the tagged values the RTF-Generator quits with an error (Document generation failed) and returns an empty document.
Since there are more than only one digram in the package I can't just add the package.
Any help would be greatly appreciated :)
rpowen
Re: RTF Documentation: add single Diagram
« Reply #1 on: January 10, 2012, 10:16:52 pm »
Niy,
One way you can achiebve this is to exclude all other diagrams in your model. To exclude a diagram, open the Diagram Properties window; on the Diagram tab there is group of options labeled "RTF Document Options". Checking teh "Exclude Image from RTF Documents" option will prevent it appearing in any RTF document.
If you want some digrams to appear in some reports and not in others, tagged values along with document searches may be one way to approach the problem.
Hope this helps,
Rob
Niy
« Reply #2 on: January 11, 2012, 01:32:42 am »
TY,
tho it didn't help :(
If I use simple/extended search from the standard searches I only get the first diagram of any result-component.
If I use a search that results a diagram the document generator failes.
