Author Topic: EAP to DBMS (SQL server) transfer  (Read 4655 times)
OpenIT Solutions
« on: January 06, 2012, 11:10:54 pm »
Hi All,
I'm getting an error whan transfering a blank EAP to DBMS - t_category does'nt exist. Well it does in the DBMS...anyone come across similar issue ? Same with 9.2 and 8.0 - so i've probably got something mis-configured - but can't see it
Any help, pointers appreciated...
ps Sparxs crashes after reporting the error....
Re: EAP to DBMS (SQL server) transfer
« Reply #1 on: January 07, 2012, 12:54:48 am »
No real idea, just a guess: user rights.
Stefan Bolleininger
« Reply #2 on: January 08, 2012, 02:00:49 am »
are you sure the EAP is really blank?
i had the same issue but with another table when i tried to move an sample project where i forgot to delete an old unused picture.
Have you tried to transfer the Standart sample project which is delivered with you installation or can be downloaded here?
« Reply #3 on: January 09, 2012, 07:31:40 pm »
I would check that:
- the sql server database is properly initialised using the latest creation script from the sparx website
- The "empty" eap file is also created by a recent version of EA.
- There's nothing strange in the "empty" eap model.
- Also check if you are using the latest EABase.eap to create a new model. (mine is dated 28/10/2011 and I'm on version 9.2.921)
OpenIT Solutions
« Reply #4 on: January 09, 2012, 08:46:52 pm »
Thanks for all responses - ill try all and feedback.
Jon.
OpenIT Solutions
« Reply #5 on: January 10, 2012, 09:27:55 pm »
Hi All,
FYI the solution was in back and white on the sparx site - all be it in the small print  :-/
"When transferring a project you must have db_ddladmin permission in order to execute the SET IDENTITY_INSERT ( table )  {ON | OFF} command"
Got my db to change my rights and all is now ok....
« Reply #6 on: January 11, 2012, 07:41:28 am »
I guess 90% of all SQL issues are due to missing rights so that's the first I try if something fails: go to the DBA and let him do it.
