Author Topic: How do I create an Activity Parameter?  (Read 5565 times)
FDavid
« on: January 05, 2012, 10:33:00 am »
EA Help is not clear, so I'm stuck!  Can anyone give me a step-by-step explanation?
Thank you!!
FDavid
RoyC
  • Read The Help!
Re: How do I create an Activity Parameter?
« Reply #1 on: January 05, 2012, 11:05:44 am »
Are you trying to create a parameter of an Activity, or an Activity Parameter Node?
There are Help topics on creating both of these objects - at what point are you stuck?
Best Regards, Roy
FDavid
« Reply #2 on: January 05, 2012, 11:20:44 am »
Roy,
Thanks for the prompt reply.
I'm trying to add an Activity Parameter Node.  The Help instruction states:
Right-click on the element and select the Embedded Elements | Add Activity Parameter context menu option.
Right-click on what element, exactly?  I want to add an activity parameter node, which attaches to the entire activity, not to a particular element within the activity diagram.
This is very easy to accomplish in RSA, but I can't seem to figure out how to do it in EA.  Thanks again for your help.
FDavid
« Reply #3 on: January 05, 2012, 11:56:06 am »
You have to right-click the Activity on a diagram. The Embedded Elements command is not on an Activity's Project Browser context menu.
« Last Edit: January 05, 2012, 11:57:05 am by KP »
RoyC
  • Read The Help!
« Reply #4 on: January 05, 2012, 03:57:40 pm »
Yes, as Neil says, you are clicking on an Activity element on a diagram (and the Activity element effectively is the diagram, as it contains other elements such as an Activity Parameter node or two).
That whole section of the Help is more-or-less a library of descriptions of creating and working with elements and connectors on diagrams.  We are gradually working through the entire Help file to make each topic more self-explanatory, so at some point in the future we might tighten up the explanations of where, when and how you create each type of object.
Best Regards, Roy
FDavid
« Reply #5 on: January 12, 2012, 08:47:44 am »
An Activity Parameter Node applies to the entire activity, not to an action or activity within an activity diagram.
Guess I shouldn't compare this to RSA, but I don't have any other point of reference, so . . . . . . within RSA, an Activity Parameter Node applies to the entire activity diagram, and visually appears as a small box on the edge of the activity diagram (not on the edge of an action or activity within an activity diagram).  The Activity Parameter Node specifies input and/or output parameters for the entire activity diagram, NOT for a specific action or activity within the activity diagram.
Perhaps RSA doesn't have such a concept?
Wish I could send you a print screen so I could show you visually what I'm trying to do.
« Reply #6 on: January 12, 2012, 09:15:46 am »
Send it to http://mailto:[email protected]
