Author Topic: Process Variation  (Read 3120 times)
e.ganesan
Process Variation
« on: February 02, 2012, 12:36:44 am »
Is there a way to capture process variation based on geography in Sparx?
Atleast can I compare elements in two BPMN diagrams in Sparx? It would be great if I can export elements in a diagram into excel and compare them?
Please share your views,
Rgds
OpenIT Solutions
Re: Process Variation
« Reply #1 on: February 02, 2012, 05:00:34 am »
There are a number of options - you could use Lanes/Pools to depict locations and place Processes/Tasks in appropriate Lanes/Pools.
My prefered approach is to create some classes in your model to represent locations - give them a stereotype of location. Then use the "Relationship Matrix" to form relationships between BPMN Tasks and Location classes.
You can then use the Model Search to create a query that pulls back all Tasks that have a relationship with a Location.
You can cut and paste the result of this search into Excel etc...
Jon.
e.ganesan
« Reply #2 on: February 02, 2012, 07:43:59 pm »
Thanks for this.
But can you please elaborate a bit on this because you are talking about BPMN and Class diagrams together. Lets assume the case that the BPMN process template is used - is there a way to associate location to the activity elements and then see that in a relationship matrix?
Suggest please.
OpenIT Solutions
« Reply #3 on: February 02, 2012, 08:43:51 pm »
So i'm not suggesting that you add classes to your BPMN diagram or that you create class diagrams (unless you want to :-)). The suggestion is that you create a seperate package in your model (via the Project Browser). You add Classes to this package with a stereotype of Location. You then use the Relationship Matrix (see help files) to form a relationships between BPMN Tasks and your Location classes.
Another approach that uses the Sparx BPMN v2 Toolbox (avalible with Sparx v9 +) would be to treat Locations as a "ResourceRole"; you can then drag and drop a ResourceRole from the BPMN 2.0 Types pallete and set the "resources" Tagged Value to the required location(s).
Personally i think the second approach is a bit poor - i'd go with the first approach above...
Jon.
