Author Topic: Problem sharing EA project via SCC / MKS  (Read 3686 times)
manfredw
  • gaudeo ligneo!
« on: February 08, 2012, 09:51:16 pm »
Hello everybody,
I've set up a project with source control using the SCC interface and MKS SCC Integration provider.
Everything works well, I can check in/out my packages etc.
The proble is that my coleagues cannot connect to this project/sourcecontrol from their machines.
I checked the version of MKS and everything and we all have the exact same versions.
- As unique ID I select the one I have used to setup the project on my computer.
- As SCC Provider I select "MKS SCC Integration"
On my machine EA shows "#/NisSoft#MDW/MMX/PlugnSign/dev/project/MMX_Model" in the SCProject field but on the my coleagues coputers this field stays empty.
I would highly appreciate any help!
Thanks in advance and have a nice day!
best regards,
Manfred
manfredw
  • gaudeo ligneo!
Problem sharing EA project via SCC / MKS [SOLUTION
« Reply #1 on: February 09, 2012, 09:25:26 pm »
well I think I have found the cause of the problem.
It was the fact that MKS applied a code review mechanism to that project and that messed up the SCC interface. ::)
Now I have a project without code review and all is well!  :)
cheers,
Manfred
