Author Topic: Default Visibility for Data Modeling Associatoin  (Read 3426 times)
brettonwoods
« on: January 25, 2012, 01:11:28 am »
The context menu in data modeling diagram for an association has the  option Visibility > Set Label Visibility. It opens a form with all options selected. The all selected default makes data diagrams very noisy. When importing a db schema with many tables it is very tedious to manually change each association.
Is there a way to set default values for the Visibility > Set Label Visibility dialog? (I know you can suppress all labels for the diagram using diagram properties - looking for middle ground)
Thanks for any help.
Tom
markus77
Re: Default Visibility for Data Modeling Associato
« Reply #1 on: February 11, 2012, 02:49:19 am »
Tom
I definitively agree with Tom.. I would like to show cardinality labels only for my database model.
Is there a way to define it for "the first" draged class pair in the diagramm and let all further imported classes behave similar?
Thanks in advance for your suggestions.
Markus
