Author Topic: Changing "Entry Point" in Scenarios of a UseCase  (Read 3948 times)
tria1312
« on: February 14, 2012, 11:26:49 pm »
I have created several UseCases and defined Constraints and Scenarios within them. I have defined some "alternative und exception pathes". But now I want to change the entry point of an exception path to another step within the basic path.
Does anyone know how I get this issue done?
Best Regards
tria1312
Eiberle
Re: Changing "Entry Point" in Scenarios of a UseCa
« Reply #1 on: February 15, 2012, 01:57:01 am »
as far as I know, you cannot alter the entry point. To change the entry point you have to switch to the basic path, select the step you want as new entry point and add a new Alternate path or Exception path, in the dialog you can then select the already existing path.
After that, you can delete the old path.
Best Regards,
Thomas Eiberle
