Author Topic: synchronisation of notes  (Read 2316 times)
Maggie
« on: February 22, 2012, 10:48:02 pm »
Hi
I am using c++ code generation and have set the option 'Synchronise notes in generation' to false.
If I create a class and enter some class notes and the generate the code, the class notes appear in the code which is what I expect.
However, if I edit the comment in the code and then synchronise the class with the code the changes are reflected in the class notes which is not what I expected.
Have I misunderstood something or am I doing something wrong?
EA version is 9.2
Re: synchronisation of notes
« Reply #1 on: February 23, 2012, 09:27:32 am »
The option that you have checked only applies to generation, not reverse engineering.
You could clear the checkbox at
Tools | Options | Source Code Engineering | Comments | Reverse
