Author Topic: Find where images are used  (Read 5262 times)
spirax
« on: February 24, 2012, 10:34:42 am »
does anyone know of a way of finding where alternate images have been used?
I have a number that have been added to the image library, all named Image<somenumber> which I want to know where they are used so that I can either rename them or delete them.
Clicking the 'Delete' button in the Image Library tells me that the Image is used by 1 Element - but doesn't tell me which one or where it is.
Re: Find where images are used
« Reply #1 on: February 24, 2012, 12:37:22 pm »
There is a button labeled "Usage" on the dialog.
spirax
« Reply #2 on: February 24, 2012, 12:39:36 pm »
Not in version 8 (build 862) there isn't.
Sorry should've stated that I'm using an older version  ::)
« Reply #3 on: February 24, 2012, 09:12:18 pm »
SELECT * from t_diagramobjects where objectstyle like '*image*'
(watch the right wildcard)
will give you a list of objects that use an alternate image. From there you can retrieve the image name and the diagram.
spirax
« Reply #4 on: February 27, 2012, 06:40:01 am »
Thanks, I didn't realise I could run a SQL query against the repository.
Unfortunately that query retures zero results. But when I drop the where clause I see that there are around 38,000 results.  The object style column seems (mostly) to be comprised of values like this:
DUID=4D71987D;
The repository I'm searching against is a MS SQL server, not a local EAP file if that makes any difference.
Any other ideas?
Cheers
« Reply #5 on: February 27, 2012, 08:42:37 am »
Yes, the wildcard character is '%' not '*'
