Author Topic: Export Model Branch  (Read 3590 times)
guyv
Export Model Branch
« on: February 18, 2012, 04:55:48 am »
While evaluating EA I noticed that I could not export a model branch (the menu item is greyed). I can import a model branch, but not export. I tried everything... The help manual provides no help for this situation...
I would appreciate any guidance you have?
Re: Export Model Branch
« Reply #1 on: February 19, 2012, 02:16:50 am »
Someone might help if you'd explain what you did.
Rhys Lewis
« Reply #2 on: February 28, 2012, 08:41:36 am »
Is that a limitation of the trial version?
« Reply #3 on: February 28, 2012, 05:11:36 pm »
Probably not. AFAIK the only limitation in the trial version if the amount of time you can use it.
philchudley
« Reply #4 on: February 29, 2012, 12:50:05 am »
If Export Model Branch is disabled it is most likely that the package under considered is not under version control.
The reason why you can import a model branch is since it is a manner in which projects can be populated from a version control repository.
Cheers
Phil
Models are great!
