Author Topic: Simulation variables - how to set?  (Read 3902 times)
« on: March 08, 2012, 12:53:13 pm »
Version 9.3 build 930.
I've setup a BPMN process (as it happens how to install SPARX EA on a client machine in a particular environment  ;)) and I now want to write a simulation script to run a particular scenario.
I have set the guards on the outbound transitions of the gateways using the (I think recommended syntax eg:
sim.EALiteNeeded==true;)
I thought I could initialise the variables in the Simulation tab of the Edit Script dialog via the Input textbox:
sim.EALiteNeeded=true;
However when it gets to the first gateway, the simulation hangs.  The two outgoing sequence flows have the conditional expressions set:
sim.EALiteNeeded==true; (and false)as required.
The Variables window shows EALiteNeeded True
Anybody know what's going on?
TIA,
« Last Edit: March 08, 2012, 12:54:37 pm by PaoloFCantoni »
Re: Simulation variables - how to set?
« Reply #1 on: March 09, 2012, 11:11:54 am »
Bump!
Sparxians?
Do I need to submit a support request?
RoyC
  • Read The Help!
« Reply #2 on: March 09, 2012, 11:30:02 am »
Yes you do. The Simulation gurus are very infrequent Forum browsers.
Best Regards, Roy
« Reply #3 on: March 09, 2012, 11:36:32 am »
I don't know for sure, but isn't the equivalence operator '=' not '==' ?
« Reply #4 on: March 09, 2012, 02:22:38 pm »
Thanks KP,
The help for "Dynamic Simulation with Javascript" explicitly says: "==".
[edit]The problem was actually caused by different bug in the Simulation process (of which there appear to be a number).[/edit]
« Last Edit: March 09, 2012, 03:50:11 pm by PaoloFCantoni »
« Reply #5 on: March 09, 2012, 04:06:34 pm »
The initialization problem is now sorted.
However, as part of the processing I'm doing, I need to set a variable to a value on an outgoing sequence flow.
The only way I can seem to get it to work is to make the flow conditional of type expression and place the variable assignment in the conditionExpression.  This, naturally, places a conditional lozenge on the argon end of the SequenceFlow.  This, I'm sure, is wrong.
So what's the correct way to assign a sim. variable in a sequence flow?
TIA,
