Author Topic: Unlinked requirement report  (Read 4040 times)
StevePinfold
« on: March 19, 2012, 10:44:22 pm »
Hi All
I am using EA for my requirements management and design.
I have used the relationship matrix to generate a requirements against realization matrix on my design and I have identified links that have been made.
I am now trying to perform analysis on unlinked requirements and would like EA to tell me of any unlinked reqs.
I have tried to use the gap analysis matrix, but it doesn't seem to do what I want.
I could export the report to a CSV and use exel to do the analysis, but I wondered if you guys have any EA tricks up your sleeves.
Thanks in advance.
S
Doug Blake
Re: Unlinked requirement report
« Reply #1 on: March 19, 2012, 11:31:07 pm »
Try validating the model. Configure with Project>Model Validation>Configure...
Tick Requirements Management
DGB Using 12.0.1214 / eaDocX 3.6.2.1 / MSSQL / TFS / Windows 7 / IE11
StevePinfold
« Reply #2 on: March 20, 2012, 12:29:42 am »
Thanks for the pointer.
That was handy way to validate the model.
From that we used that pointer to dig in the help in a different direction and found out how to do a implementation report on a requirements package.
Project | Documentation | Implementation Details.
and this is close enogh to what we are after.
Thanks again
S
Dermot
« Reply #3 on: March 21, 2012, 09:58:40 am »
There is also a default search (Ctrl+F) called "Find Orphans".
RoyC
  • Read The Help!
« Reply #4 on: March 21, 2012, 02:35:32 pm »
Ye-e-sss - The report shows elements that are not used on any diagram, and that generally (but not exclusively) means elements that have no connectors.
Ctrl+F displays the Model Search screen. In the Search field select Find Orphans from the drop-down list, and in the Search Term field type Requirement.
Click on the package or model to search, and click on the Run button.
Give it a try and see how close it is to what you want. If you have lots of unlinked Rquirements created on a diagram, the report might not help. If you have Requirements in the Project Browser that you add to a diagram in order to link them to each other or to a Use Case, the report could be very useful.
Best Regards, Roy
