Author Topic: Code Engineering  (Read 2739 times)
jdavid
Code Engineering
« on: March 29, 2012, 07:36:29 am »
When using the 'Sync Package With Code' option within Software Engineering, how do you specify the EA should delete any existing classes in EA that are not in the existing code base.
Example: Class was deleted in code base, but shows up in the Export Model To Code window when EA has completed analysis between the code base and the model
Re: Code Engineering
« Reply #1 on: March 29, 2012, 08:35:50 am »
Use Import Source Directory instead.
