Author Topic: Creating a new template in C# code  (Read 6166 times)
Cleber.Hans
« on: April 18, 2012, 03:28:01 am »
Good afternoon.
I need to know how to create a specific template to generate the following codes to standard output in C #.
public class Pais{
public int PaisId{get; set;}
public string Nome{get; set;}
« Last Edit: April 18, 2012, 03:28:26 am by CleberHans »
g.makulik
Re: Creating a new template in C# code
« Reply #1 on: April 18, 2012, 07:42:30 am »
Hi Hans,
It's a bit unclear for me, what exctly you want to know.
a) How to write a code generation template that generates this code
b) How to model a class that EA c# standard templates generate this
    code.
For a) I would recommend to have a look at the C# code generation templates.
If it's b) that should be fairly easy. Create a class named 'Pais' on a class diagram and give it the attributes 'PaisId' and 'Nome'. Change the attributes' stereotype to <<Property>>.
Ensure that the classes language is set to C#, and start code generation.
Günther
Cleber.Hans
« Reply #2 on: April 18, 2012, 08:00:07 am »
Gunter, good evening!
[size=12]What I want is to generate automatic properties in C #[/size].
For example, observe the class Country:
public class Pais {
      private string nomePais;
      private string siglaPais;
}//end Pais
The code should be:
public class Pais {
      public NomePais {get; set;}
      public string SiglaPais{get; set;};
}//end Pais
I have no idea how to generate this code.
« Last Edit: April 18, 2012, 08:02:44 am by CleberHans »
« Reply #3 on: April 18, 2012, 03:32:00 pm »
Isn't there somewhere a checkbox that you can set to indicate that an attribute is a property?
« Reply #4 on: April 18, 2012, 04:44:40 pm »
The {get; set;} syntax can be achieved by giving an attribute the «property» stereotype. Don't click the "Property" checkbox for the attribute because that will give you the longhand syntax.
Cleber.Hans
« Reply #5 on: April 18, 2012, 11:05:25 pm »
Hi KP, thanks a lot for your answer.
I know your answer is correct, but let me replace my problem:
I would like the standard output (get set) generates the system was placed on the same line and PascalCasing rating.
That's it.
« Last Edit: April 18, 2012, 11:06:32 pm by CleberHans »
Makulik
« Reply #6 on: April 18, 2012, 11:56:41 pm »
Hi Hans,
Under 'Tools->Options->Source Code Engineering' there's a checkbox named 'Captialized Attribute Names for Properties'. Did you already try that?
If this won't help you would really need to adapt the C# Code Generation Templates accordingly. Have a look at the 'Attribute Declaration' template.
When I was looking at it I've also seen that it expects a tagged value 'Automatic' at the attribute to generate C# auto field properties.
Günther
Cleber.Hans
« Reply #7 on: April 19, 2012, 01:49:18 am »
Hi Gunther,
Their response worked.
      /// <summary>
      /// Designa o nome da cidade.
      /// </summary>
      public string NomeCidade{
            get{
                  return nomeCidade;
            set{
                  nomeCidade = value;
Now I need to customize the output to remove
the code: (return nomeCidade and nomeCidade = value)
g.makulik
« Reply #8 on: April 19, 2012, 02:48:44 am »
I think that's achievable using the tagged value I mentioned ...
Günther
PS: As a hint I want to advise you really to have a look at the standard code generation templates, if you want to use code generation extensively. You should get a good grip, what might be generated exactly and the dependencies from code generation options, stereotypes and tagged values. You can access the templates using 'Settings->Code Generation Templates' and choose C# in the Language drop down.
You can find more information about the conditions used here:
http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/standard_uml_models/fieldsubstitutionmacros.html
« Last Edit: April 19, 2012, 03:00:23 am by g.makulik »
Cleber.Hans
« Reply #9 on: April 19, 2012, 03:14:07 am »
Gunther, You're really fantastic. I study and I will post soon.
Again, thanks a lot.
Hans
