Author Topic: Profile problem  (Read 3558 times)
mrpmorris
Profile problem
« on: April 19, 2012, 10:02:11 pm »
I have created a profile, then saved it as a profile.
Then I created a class using my NHEntity stereotype from the tool box.
I see my "TableName" tagged value in NHibernateProfile as expected.
I have now added another attribute to my NHEntity metaclass, saved the profile, and then reimported the profile into my test project.  New NHEntity classes added to my model have the new IDType value, but NHEntities created before the re-import do not.
----UPDATE----
This is also apparent in specifying that an attribute is an enumeration.  Here is the profile
At first the enumeration wasn't in the profile and the IDType was a string.  I later changed it to an enumeration.
After re-importing the profile I see that the class I originally added to my test project does not realise it is an enumeration
Whereas a class I add to the diagram after re-importing does
----/UPDATE----
It seems the template's metaclass attributes and their types are only added to the new class when it is created, and not re-applied when the profile is re-imported.
This would be a major pain if I had a large model and for some reason had to re-import a modified profile.  Is there a step I am missing, or does EA simply not do this?
« Last Edit: April 19, 2012, 10:25:47 pm by mrpmorris »
Re: Profile problem
« Reply #1 on: April 19, 2012, 10:23:13 pm »
You have to Synch Tagged Values from the context menu of your specific element in the Toolbox.
mrpmorris
Re: Profile problem
« Reply #2 on: April 19, 2012, 10:41:46 pm »
My opinion of that is that it is unintuitive, and shouldn't even be necessary.
Thanks for the answer though! :)
