Author Topic: Does "Sort Features Alphabetically" work in 6.3?  (Read 3843 times)
Daaz
« on: April 30, 2012, 10:25:00 am »
I've got Tools->Options->Objects->Sort Features Alphabetically enabled.  The help says that this should "Sort element features alphabetically. Features include Attributes, Operations, Tags, Constraints and Test Cases".  Yet when I add a new attribute or operation, it is not sorted.
Am I using the right option?  Is there another way to sort everything?
Re: Does "Sort Features Alphabetically" work in 6.
« Reply #1 on: April 30, 2012, 03:05:44 pm »
6.3 really? :o
There's also an option somewhere that allows free sorting. I can imagine that the two options somehow collide.
« Reply #2 on: May 01, 2012, 08:50:37 am »
Given that it went from 6.1 to 6.5, I'm going to guess that the 6 and 3 were inverted. (ie. 9.3)
9.3 works correctly with the restriction that it doesn't operate on enumerations and tables where the order is actually important.
Geert, Sort Features Alphabetically sorts attributes and operations within classes. Allow free sorting stops the project browser from enforcing that different element types will appear before others in the tree.
Daaz
« Reply #3 on: May 01, 2012, 10:32:55 am »
Ah, yes, version is 6.5, not 6.3.
I'm using tables, which explains why it doesn't sort.  Is there any way to sort them rather than moving each attribute manually?
