Author Topic: MDG Shape scripts and extended nodes not working  (Read 2825 times)
AndrewW
« on: May 01, 2012, 06:48:03 pm »
I’ve been working with MDG technologies extending both nodes and execution environments for deployment.
I can get shape scripts to trigger for extended execution environments, but not for extended nodes.
If I change the extension from node to execution environment then shape script works
I have even tried very basic shape scripts with just a println statement in
Any idea why and how to get shape scripts to work with extended nodes using MDG?
Kind Regards
Andrew
Re: MDG Shape scripts and extended nodes not worki
« Reply #1 on: May 01, 2012, 06:57:56 pm »
I guess only by sending a bug report.
AndrewW
« Reply #2 on: May 01, 2012, 09:37:19 pm »
Found the issue.
I had a sterotype with the same name which also applied to nodes in the EA instance I was using for testing of the MDG.
Once i removed the sterotype everything started to work
Andrew
