Author Topic: SysML flow ports compartment suppression  (Read 4699 times)
DanG83616
« on: May 05, 2012, 05:32:08 am »
How can I suppress the SysML Block flow ports compartment? When I show the block with embedded elements visible I don't need the compartment on.
Dan
philchudley
Re: SysML flow ports compartment suppression
« Reply #1 on: May 06, 2012, 01:25:47 am »
If you are using EA version 9.3, right-click on the BDD diagram background, and click the Elements tab.
You should see check boxes to suppress the ports, parts, values
Cheers
Phil
Models are great!
DanG83616
« Reply #2 on: May 06, 2012, 05:52:08 am »
Duh. Thank you for being willing to play "Mr. Obvious." I looked at that dialog box so many times but it took you saying that the option was there for me to see it.
