Author Topic: ecore generation  (Read 2294 times)
Vincent Legendre
ecore generation
« on: May 16, 2012, 02:14:40 am »
I’m trying to export an EA model to ecore with the new function in EA9.3
Some issue lead to an unusable ecore file and many things modeled in UML aren’t represented in generated ecore .
Here some example: nsPrefix not defined, no default value in enum, containement tag are not generated, EA tag and comment aren’t exported…
- Am I missing something (any configuration?) to generate a proper ecore file?
- Is there any way to personalize the generation process? (Maybe a similar mechanism to code generation)
- As anybody meets similar issues, which solution did you choose?
« Last Edit: May 16, 2012, 02:15:20 am by vincent.legendre »
