Author Topic: Hide Parent Arrows  (Read 3839 times)
GOCE
Hide Parent Arrows
« on: May 15, 2012, 10:11:19 pm »
Hello
I would like to know if there is a way to automatically hide parent arrows in every diagram
Thank you
Re: Hide Parent Arrows
« Reply #1 on: May 15, 2012, 10:26:09 pm »
What is a "Parent Arrow"?
GOCE
« Reply #2 on: May 15, 2012, 10:57:57 pm »
In a Data Flow Diagram I can set a process as a child of another process (ctrl+i). When I drag the parent process and the child process in a new diagram it appears a white arrow linking parent and child. I can manually delete it but I'd like to know if there is a way to hide them all automatically.
« Reply #3 on: May 15, 2012, 11:22:03 pm »
So the arrow you are talking about is the "Generalization" relation.
Are you sure this is what you want?
The generalization can be read as "is a" so in your case
child process "is a" parent process.
Looks a bit strange.
GOCE
« Reply #4 on: May 15, 2012, 11:34:17 pm »
Yes, this is definetly what I want
philchudley
« Reply #5 on: May 16, 2012, 12:25:30 am »
There is a way to do this semi automatically.
Create the diagram with all of the generalization links (parent arrows)
Select Diagram | Advanced | Visible Relations... from the main menu
On the list that appears, check all the Generalization links
There you are, all hidden.
Cheers
Phil
Models are great!
GOCE
« Reply #6 on: May 16, 2012, 06:23:57 pm »
Thank you! It's seems this could be a solution!
Cheers
