Author Topic: i have lost my password for my eap file  (Read 6359 times)
alvarotovar
« on: May 17, 2012, 09:57:20 am »
Hello
I have a old .eap file, and i don't know the password for this file, is there a way to open the file without the password? o a password recovery or craker?
thanks
Aaron B
Re: i have lost my password for my eap file
« Reply #2 on: May 17, 2012, 12:34:26 pm »
Do you know if it's a database-level password, or is it EA's User Security feature that is prompting?  Is EA just asking for a password when opening the file, or a username and password?
If asking for a username and password, it is most likely just EA's User Security.  Try entering "admin" and "password" (these are the default credentials created by EA when security is first enabled).  If that fails, please contact [email protected] and we should be able to provide some further guidance.
philchudley
« Reply #3 on: May 17, 2012, 06:29:56 pm »
You could modify the underlying table structure directly, by
setting the column [highlight]UserSecurity[/highlight] in the table [highlight]t_secpolices[/highlight] to anything other than Enabled
This may fool EA into believing that there is no security and hence no prompt for password.
However the passwords will still be set in[highlight] t_secuser[/highlight] table
So a drastic move would be to remove all rows from[highlight] t_secpolicies, t_secuser[/highlight] and [highlight]t_secusergroup[/highlight]
and then start all over with the security
Best of luck
Cheers
Phil
Models are great!
« Reply #4 on: May 17, 2012, 08:11:38 pm »
I can confirm what Phil said: just clear t_secpolicies and security is turned off. I have a section about user security in my book (see link below). You can also copy a known user password to your admin's password.
(Or set the admin password to  5PDCD_FT which will enable the standard password)
« Last Edit: May 17, 2012, 08:15:46 pm by qwerty »
alvarotovar
« Reply #5 on: May 18, 2012, 12:04:36 am »
many thanks to all, i used admin / password and i open the file.
a lot of thanks
