Author Topic: Defining base tools for classes  (Read 3136 times)
LeventKent
« on: May 31, 2012, 12:34:13 am »
Hi everyone,
we just upgraded form EA7.5 to 9.2 and I am very happy with the bug fixes.
I now have one question:
We have a Java application with strict types of components with predefined interfaces.
For example every component in business layer needs to be annotated with @Service such as:
@Service
public class MyBusinessBean {}
I want to specify some class templates, which the technical designers would use (through drag&drop) to model such components.
For example they would select the element BusinessBean and drag&drop to the class diagram and the stereotype would be there automatically.
Is there a convenient&easy way to sepcify such customized tools for modeling in EA?
Thanks in advance,
Levent
« Last Edit: May 31, 2012, 12:34:49 am by LeventKent »
Re: Defining base tools for classes
« Reply #1 on: May 31, 2012, 12:56:18 am »
LeventKent
« Reply #2 on: June 01, 2012, 12:03:56 am »
thanks for your advice. MDG looks cool, however I tried yesterday the "UML Pattern" way.
I did define some patterns, which includes the necessary classes for our components. However, I have one problem:
The binding expressions of the classes are not created when the technical designers drag & drop the UML patterns to the class diagram.
For example an interface like:
public interface IWagenRDataAccess extends IReadDataAccess<Wagen>
is modeled in EA through Binding expressions.
After I model the pattern in a class diagram and save it as a pattern, I can see through the preview of the pattern that the bindings are still there. On the otherhand, if someone tries to apply the pattern the bindings disappear.
Is this a bug of EA? Are there any work arounds?
LeventKent
« Reply #3 on: June 04, 2012, 09:44:18 pm »
Hi again,
I found the workaround for bining expressions. You need to put the paramterized class (to which you bind your other classes) to the template diagram (not create just put a drag&drop a link to the diagram). Just referencing to it through binding expressions does not help for UML patterns.
Thanks for the replies...
