Author Topic: Tagged Values in RTF Report without «stereotype»?  (Read 3573 times)
jrueting
« on: June 03, 2012, 07:40:33 pm »
I am trying to create a RTF template to print a list of tagged values. This works so far that I have added a table in the RTF report in which I insert the tagged value using <insert field> <value of> and providing the tagged value name. The RTF report shows correctly the values of the tagged values, but unfortunately each value has as prefix the stereotype of the tagged value, e.g. «ReqApplicability» Subsystem, or  «VerificationMethod» Test. This overloads the RTF document with EA internal information.
Is there a way to turn-off this prefix and to show just the tagged value?
Michael Proske
Re: Tagged Values in RTF Report without «stereotyp
« Reply #1 on: June 06, 2012, 10:26:40 pm »
I assume that you use Reference Tagged Values to other elements. If yes then there is no way to avoid printing of the stereotype because it is a feature not a bug. I wrote a bug report because in former versions the behaviour was different but they told me it is implemented as designed.
