Author Topic: link Basic Path text to Robustness diagram note  (Read 2822 times)
Ronald Wouters
« on: June 09, 2012, 07:47:32 am »
Hi all,
when creating a robustness diagram for a use case (Iconix) the generated diagram shows a Note element.  The text on this note is taken from the "Notes" field of the general properties of the use case.
Under Rules --> Scenarios of the use case properties, you can enter a "Basic Path" or "Alternate" scenarios.  These scenarios can have a plain text "Description" or a "Structured Specification".
How do I make either the Description or the Structured Specification text appear on the Note element of the robustness diagram instead of the text of the general Notes field of the use case properties ?
Ronald Wouters
Re: link Basic Path text to Robustness diagram not
« Reply #1 on: June 09, 2012, 11:39:23 pm »
Context of note link
Link to element feature
Structured scenarios
Ronald Wouters
« Reply #2 on: June 11, 2012, 03:14:44 pm »
Thanks for your reply.
The problem was that I first had to drag the use case onto the robustness diagram, then create a link from the diagram note to the use case.  Only then could I access the context menu of the link to "re-link" it to the structured scenarios.  I had hoped not having to do that.
Regards.
