Author Topic: Permission issue  (Read 3804 times)
hano08
Permission issue
« on: June 18, 2012, 10:10:55 pm »
We have a file-based eap that works fine for 3 users on a shared network. However, today a new user were invited to start working with this eap, but she´s not able to open it.
The error-message reads something like:
"....It is already opened exclusively by another user, or you need permission to view its data"
No other user had that eap opened at the time.
Did a copy from that file, wich she was able to open.
Any help would be greatly appreciated.
Thank you,
Re: Permission issue
« Reply #1 on: June 18, 2012, 10:43:56 pm »
a .eap file is an ms-access database.
If you open a .eap file it creates a .ldb "lock file".
Delete the lock file and you should be able to open the .eap file again.
hano08
« Reply #2 on: June 19, 2012, 09:43:10 pm »
Thanks Geert for your reply.
Problem is that it is not possible to delete the .ldb. Error message reads "Cannot delete <filename>: It is being used by another person or program. Close any programs that might be using the file and try again."
Based on that you would think that there is a person who has the eap opened, but they assure me that is it not. There are four people sharing this eap.
Person A and B manage to open, edit and close the model. Person C and D cannot open the model at all. Person A is the one that created the eap originally, and that person is unable to delete the .ldb
Any other ideas?
Hano
« Reply #3 on: June 19, 2012, 09:49:35 pm »
Yep. The usual windoze solution: reboot!
« Reply #4 on: June 19, 2012, 10:10:22 pm »
Hano,
I would try to search google for this issue as it is a typical MS-Access problem. There must be other MS-Access users that had the same issue.
hano08
« Reply #5 on: June 20, 2012, 05:29:51 pm »
Ok,
Thanks. I try that, or I just make a copy of the file.
