Author Topic: Display of elements from other packages  (Read 2579 times)
MarkAH
« on: June 22, 2012, 06:11:44 pm »
Hi
I've defined several packages across my model, within which i then define elements. I can use elements defined in package A in a diagram for package B, but when doing so EA always puts a "(from xxxx)" subtitle next to the element in package B.
Is there a way to hide this subtitle within the diagram?
I've checked across these forums and the Sparx website but not found anything on this subject.
SomersetGraham
Re: Display of elements from other packages
« Reply #1 on: June 22, 2012, 06:43:54 pm »
Hi
Display the diagram properties dialog
Pick the Diagram tab
Uncheck the ShowNamespace check box
hth
Using V12
MarkAH
« Reply #2 on: June 22, 2012, 10:37:22 pm »
That's it, thanks!
Didn't even realise it was a Namespace...
