Author Topic: C# signature for Addin.EA_OnStartValidation()  (Read 4326 times)
Manfred Kröpfli
« on: March 31, 2009, 08:55:04 am »
Hi
I want to use the Addin trigger method EA_OnStartValidation() as described in the EA User Guide, but I need the C# version of it. I tried:
C#:
public void EA_OnStartValidation(EA.Repository Repository, params object[] Args)
as a replacement for the documented VBA signature:
VBA:
Sub EA_OnStartValidation(Repository As EA.Repository, ParamArray Args() as Variant)
but without success. I get the error message: "EA_OnStartValidation(): invalid parameter(s)". How does the correct C# method signature look like?
Manfred
« Last Edit: March 31, 2009, 08:55:45 am by kroepfli »
Cheers
Manfred
Makulik
Re: C# signature for Addin.EA_OnStartValidation()
« Reply #1 on: March 31, 2009, 11:03:46 pm »
Hi Manfred,
You might try simply
object Args instread of,
params object[] Argsand try to cast Args to the object array internally. Don't know if this will work, just an Idea ...
Günther
Manfred Kröpfli
« Reply #2 on: April 01, 2009, 07:40:19 pm »
Günther
you intuition was good. Following C# code works fine:
public void EA_OnStartValidation(EA.Repository repository, object  argsObject) {
    string[] args = (string[])argsObject;
Beste Grüsse
Manfred
Cheers
Manfred
