Author Topic: Usecase through javascript code  (Read 3984 times)
swettdj
« on: July 12, 2012, 11:06:01 pm »
I'm trying to create a script to automaticate usecase's step creation but every step that I creat through javascript code is set as System step. How can I set user step?
And after, I need to create an alternative path for a determinated step,can someone explain me how do it? :o
Re: Usecase through javascript code
« Reply #1 on: July 13, 2012, 03:36:34 pm »
Do you realise that the whole API is documented in the help file?
See http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/automation/scenariosteptype.html for a start
swettdj
« Reply #2 on: July 13, 2012, 06:21:25 pm »
I had solved my problem with settig user and system step..but how set an alternative path on a step through javascript??
thanks
« Reply #3 on: July 16, 2012, 05:57:42 am »
I've added a chapter about that to my Scripting book in case you are a subscriber. Here's the meta-
       alt = element.Scenarios.AddNew ("alternate", "Alternate");
        altS = alt.Steps.AddNew ("alt step1", "1");
        altS.Update();
        scenario.Update();
        scenario = element.Scenarios.AddNew ("scenario", "Basic Path");
        s = scenario.Steps.AddNew ("step1", "1");
        s.Update();
        ext = s.Extensions.AddNew ("", alt.ScenarioGUID);
        if (tilEnd) ext.Join = "";
        else ext.Join = s.StepGUID;
        ext.Update();
        scenario.Update();
swettdj
« Reply #4 on: July 16, 2012, 05:22:16 pm »
Thank you for reply, but I solved it friday afertnoon...but thank you very much
« Reply #5 on: July 18, 2012, 11:25:51 am »
so how did you solve it ...
swettdj
« Reply #6 on: July 18, 2012, 05:22:44 pm »
for alternative path i solved it with this source code:
st = steps.GetAt(n);
extensions = st.Extensions;
extension = extensions.AddNew("Step "+n+" Alternative flow","Alternate");
sceneAlt = extension.Scenario;
stepsAl = sceneAlt.Steps;
stepAl = stepsAl.AddNew(name,"Alternate");
stepAl.Update();
stepsAl.Refresh();
sceneAlt.Update();
steps = scene.Steps;
step = steps.GetAt(n1);
extension.Join = step.StepGUID;
extension.Update();
extensions.Refresh();
If you need other any other explanation write me I'm happy to help you
