Author Topic: Shape Script for actor <<stakeholder>>  (Read 3512 times)
bioform
  • Forty-Two?
« on: April 03, 2009, 02:35:13 pm »
Been working on learning  to use shape scripts. Bit of a learning curve.
I am thinking about starting a how-to thread on shape scripts with some actual scripts I use, so if anyone has an interest in the topic let me know
Anyway, I wanted an easy way to make sure I understand which type of actor I was looking at (e.g., Is that the customer actor, or the customer stakeholder?) This script helps me not get confused...
To try out (if not familiar with):
  • Create a diagram (use case) and drag an actor element and drop on diagram.
  • Move to the stereotype drop-down box and TYPE "STEAKHOLDER", then SAVE. We are using THAT name for this demo so you don't overwrite an existing actor, stereotyped as a stakeholder, should one exists.
  • Select the actor (just click to select, not open)
  • Select menu option "Settings", then "UML"
  • UML Types window is displayed WITH your STEAKHOLDER stereotype already selected.
  • In the "Override Appearance) set of controls, click the radio button for Shape Script, then the Assign button.
  • Shape Editor window is displayed.
  • Cut and paste the script below into the window and the click refresh.
  • If you copied the entire script between the blocks, you should see a lousy looking image in the preview pane, don't worry about it, just click OK
  • Return to UML Types window, and click save.
  • Take a look at your actor now.. :) Easy to now tell the difference between an actor and the stakeholder
I left in place holders for the order that I place the code in... I sure wish the guide made it clearer tough to figure out without getting fustrated...
If anyone is interested in a more advanced shape script that I use with use cases, just send me a message.
Goodnight and back to modeling...
"Hey, you want to get that spot out of my eyes, I'm trying to work here!"
Script Starts Below
// Author - David Rains ([email protected]) Copyright 2009
// Release:
// Script Version: 1.0
// Script's Purpose: Display adornment for actors stereotyped as stakeholders
Shape Main
      //Default PROPERTY Initializations (Must be at TOP)
      noShadow = "false";
      dockable = "none";
      //Check for Required Tagged Values
      //PreDraw Derived Attribute Initializations
      //Draw Shape
      drawnativeshape();
      //PostDraw Adornments
      //Stereotyped Static Adornments
            //Add Stakeholder's STAKE
            setpenwidth(3);
            // Add a the Stakeholder Indicator
            startpath();
                  moveto(25,37);
                  lineto(25,52);            // draw "|"
            endpath();
            strokepath();
            //Add tip
            setpenwidth(1);
            startpath();
                  moveto(24,52);
                  lineto(25,56);
                  lineto(27,52);
            endpath();
            strokepath();
      //Stereotyped Dynamic Adornments
Script Ends Above
Time is what keeps everything from happening at once, Space is what keeps it all from happening to you. <unknown>
