Author Topic: Attaching a diagram to an existing connector  (Read 3132 times)
supplyondemand
« on: July 18, 2012, 11:47:22 pm »
I wonder if it is possible to attach an element (i.e. a diagram) to an existing connector (that is already connecting two elements or two attributes respectively)?
The (simplified) use case is: I want to model the relationship between attributes of EDIFACT messages and XML formats.
I can do this by defining classes for the EDIFACT and XML and connect their attributes (Link to element feature). This works well for the simple case of a direct transformation EDIFACT -> XML. And this connection / relationship is the main information I want to model.
However, it is possible that the value of the EDIFACT message is not simply copied to the XML but a more complex process is carried out to make the transformation.
So my idea is to model the relationship between two attributes through a connection (i.e. assoziation) and attach a process diagram if necessary.
Is this possible / feasible?
Thanks a lot for any input.
Re: Attaching a diagram to an existing connector
« Reply #1 on: July 19, 2012, 12:05:41 am »
A connector always connects two elements. And never a diagram.
In your case you should use an association class (displays as a lozenge. This can connect more than one element.
« Reply #2 on: July 19, 2012, 03:17:37 pm »
If by "process diagram" you mean Activity Diagram, then I would try to link an Activity (containing that Activity Diagram) to the connector.
You can use a tagged value of type RefGUID to create the link.
(you can navigator from the relation to the activity and back using my EA Navigator Add-in)
