Author Topic: customised associations  (Read 4192 times)
bacz
« on: July 20, 2012, 05:29:40 pm »
I am using Sparx Enteprise Architect for, here's a novelty, Enterprise Architecture modelling.
I am linking Data to technology to applications to business capabilities etc.
Linking them using the standard association tools, e.g. compositions, traceability etc. creates very complxed information overload in the traceability screen.
I have tried to create my own unique assoications but without much luck, as the base class of say association, stays the same.
My question is :
1. Is there anyway I can customize the traceability association name labels , from say "depends on" to references? e.g. make them more user friendly?
2. I have a big need for custom references, but I also need a diagrammatic way to represent these associations, not just the custom manager, is there a way to do that?
3. Are there ways of seperating a class association in traceability form, from say extends or use case links as they all come up the same?
Thanks every so much, a great product, this is my only bug bare
« Last Edit: July 20, 2012, 05:31:13 pm by bacz »
Re: customised associations
« Reply #1 on: July 20, 2012, 05:53:06 pm »
You should probably checkout Profiles (or use one of the standard profiles available such as Archimate)
bacz
« Reply #2 on: July 20, 2012, 07:30:40 pm »
Hello Geert,
Thanks for your quick response.
I've trying using profiles, unfortunately if you say, create a stereo type of a Trace, the sub class is of type trace, and the description in the traceability window is "depends on".
What I am doing is looking for a way to change "depends on" to "references" or "is appreciated with" etc., do you think I could do that in an existing profile? How would I go about doing it, in say Alchimate?
Thanks for your help,
Gary
« Reply #3 on: July 20, 2012, 07:40:58 pm »
Ah, so you want to change the description in the traceability window.
No, I don't know if that is possible.
« Reply #4 on: July 20, 2012, 10:18:45 pm »
What is you intention in renaming the dependency? If they are indeed different flavors you should name them from the beginning. And you should do that either via a profile to support that or by selecting the appropriate values from the stereotype drop down (which does only suggest but not limit the range).
(I like the typo in "Alchimate")
