Author Topic: Entity Stereotype  (Read 3086 times)
Rafael Santini
Entity Stereotype
« on: July 27, 2012, 10:58:40 am »
Why the class diagram is changged to a circle when the stereotype is setted to Entity?
« Last Edit: July 27, 2012, 10:59:02 am by rafaelsantini »
Re: Entity Stereotype
« Reply #1 on: July 27, 2012, 03:05:47 pm »
Because of the entity-boundary-control pattern.
I'm not sure if they are "hard-coded" build-in or not, but I would try to remove the stereotypes in Setting|UML Types...
(make sure you don't have any instances still using the stereotype before removing it)
Dermot
« Reply #2 on: July 27, 2012, 03:23:34 pm »
You can disable Icons in the diagram
- right-click on the diagram
- Properties | Elements tab
-  untick [] Use Stereotype Icons
