Author Topic: Properties: Redefinition: Display in EA 9.0  (Read 4374 times)
Michael Hafner
« on: July 30, 2012, 08:02:23 pm »
Dear all,
is there any possibility to display the redefinition of a property on a diagram?
I think, documentation of an earlier version (7.*?) had it that attributes with identical names would "be merged" somehow in this case:
Att_01 isAttributeOfClass Cls_01 &&
Att_01 isAttributeOfClass Cls_02 &&
Cls_02 isSubClassOf Cls_01
(Cls_02.Att_01 being regarded as a redefinition of Cls_01.Att_01)
However, the feature did not seem to work at the time, and obviously has been discarded. According to UML 2.3 (http://www.omg.org/spec/UML/2.3/Superstructure/PDF/), redefinition should be stated thus:
‘redefines’ <property-name>
So that, in the context of Cls_02,
Att_01 {redefines Att_01}
EA has a very efficient way to model redefinition, but is there a way  to display it  as well - ?
Best,
Michael
Re: Properties: Redefinition: Display in EA 9.0
« Reply #1 on: July 30, 2012, 08:25:59 pm »
I know it works correctly for associations, but I've never tried it on attributes.
Michael Hafner
« Reply #2 on: July 30, 2012, 09:49:24 pm »
It's a little confusing:
1. Associations: Via tabs Association Properties > Source|Target Role > Qualifiers, you reach a tab, Detail, which is about redefinition, however, all the controls are disabled. No redefinition is shown, even if it's there. You have to use the context menu Advanced - always a good bet - and select Association Specialization. Now you can assign a redefinition, albeit only one. But it works, like you said.
2. Attributes: Attribute Properties > Detail. Here, the controls work, you can even assign multiple redefinitions. But they aren't shown anywhere, and I haven'd discovered any visibility option so far.
M.
« Reply #3 on: July 30, 2012, 09:54:14 pm »
In short: EAUI :-X
