Author Topic: Complext type with simpleContent in XML Schema UML  (Read 4217 times)
Zak
« on: August 02, 2012, 09:35:48 pm »
I am trying to figure out how to model XSD Complex Type with simple content using XSD Uml profile in EA 9.3.
Is there a way to  to model it in UML using the XSD Profile in order to achieve such output ?
<xs:complexType name="testType1">
    <xs:simpleContent>
      <xs:extension base="xs:integer">
        <xs:attribute name="country" type="xs:string" />
      </xs:extension>
    </xs:simpleContent>
  </xs:complexType>
The Generation mechanism seems to convert XSD Complex types into sequence/chocie/all elements but I didn't find how to model simpleContent .
I suppose there is also no way to change  the XML schema generation logic (XSD UML -> XSD code) in order to impact these settings.
Has anyone come across such requirement and figured out how to do it?
Re: Complext type with simpleContent in XML Schema
« Reply #1 on: August 02, 2012, 10:52:25 pm »
Can't you just import the xsd to see what EA makes of it?
