Author Topic: tuning off line crossing hoops  (Read 4312 times)
James42
« on: February 04, 2012, 03:31:42 am »
Hi, how can I disable line crossing hoops (little hoop in line where 2 line cross) ? Annoyingly they appear in some crossings and not others and diagrams look bad because of this.
    James
philchudley
Re: tuning off line crossing hoops
« Reply #1 on: February 04, 2012, 11:59:51 pm »
From the main menu select Tools | Options...
Then select the Diagram node
Under the General Check Box group, uncheck the checkbox labelled Enable Connector line jumps
This will have the effect you want on all your diagrams
Cheers
Phil
Models are great!
James42
« Reply #2 on: February 05, 2012, 11:17:08 pm »
That's great. Thanks Phil
pakcom
« Reply #3 on: September 04, 2012, 06:24:31 pm »
Why can't I find Enable Connector line jumps option?
My EA version EA 8.0.
Does it have different setting for connector line jump?
Thanks..
philchudley
« Reply #4 on: September 04, 2012, 07:30:03 pm »
As far as I remember, this feature was added in EA version 9.0 and hence is not available in EA version 8.0
Cheers
Phil
Models are great!
