Author Topic: Is 1...n the simplified notation of0..1 <--> 0..n  (Read 5061 times)
pstein
« on: May 30, 2012, 10:55:02 pm »
When creating a class diagram then sometimes the designer and authors talk about 1-n relationsships.
On other places the multiplicity is more detailed e.g.
0..1 <---->0..n
Is it the same?
Or does the "1" in an 1-n relation ALWAYS mean ONLY 1..1 and "n" always ONLY an 1...n relation? Mind the exclusion here of the "0"!
Peter
Re: Is 1...n the simplified notation of0..1
« Reply #1 on: May 31, 2012, 09:51:31 am »
In my opinion, the following are all 1-to-many relationships:
[1] <---> [1..*]
[1] <---> [0..*]
[0..1] <---> [1..*]
[0..1] <---> [0..*]
The "0" in each case denotes optionality. If you don't want to clutter your model with detail on optionality, choose:
« Last Edit: May 31, 2012, 09:53:18 am by KP »
« Reply #2 on: May 31, 2012, 03:28:29 pm »
The only "optional" thing is the "0.." in [0..*]
So
[*] == [0..*]For the rest, is it as expressed.
So
[1] == [1..1] != [0..1]
PS. I don't think [0..n] is valid UML syntax.
« Last Edit: May 31, 2012, 03:52:55 pm by Geert.Bellekens »
« Reply #3 on: May 31, 2012, 03:43:06 pm »
Geert, I was talking about meaning not syntax. Example:
Vehicle [0..1] <---> [0..*] WheelVehicles may or may not have wheels - wheels are optional. A wheel may or may not be attached to a vehicle - the vehicle is optional.
Your comment on the syntax is correct (at least it would be if YaBB hadn't hidden your '[ * ]'  - it did the same to me  >:( ). I'll just add that [1] is also optional syntax, and can be assumed if no multiplicity is shown.
« Last Edit: May 31, 2012, 03:44:00 pm by KP »
« Reply #4 on: May 31, 2012, 03:52:19 pm »
I know, I wasn't trying to contradict you.
Ah, now I see why you could think that, because I also used "optional".
We were absolutely talking about two different "optional"s
PS. I'll fix the [ * ] thing
pstein
« Reply #5 on: September 09, 2012, 04:11:16 pm »
So
So
[1] == [1..1] != [0..1]Geert
Ok, thank you.
But is this somehow officially defined?
Not that I doubt on your statement, but I need a proof for other colleagues:
Where can I read/verify this?
Is there an (semi-)official,central UML 2.0 syntax reference web page?
Thank you
Peter
« Reply #6 on: September 10, 2012, 09:49:39 am »
Thank you
Peter
The UML spec can be downloaded free from the OMG website at http://www.uml.org/
Have a look at section 7.3.33 MultiplicityElement. Under "Presentation Options" it says:
If the lower bound is equal to the upper bound, then an alternate notation is to use the string containing just the upper bound. For example, “1” is semantically equivalent to “1..1”.
A multiplicity with zero as the lower bound and an unspecified upper bound may use the alternative notation containing a single star “*” instead of “0..*”.
« Last Edit: September 10, 2012, 01:39:59 pm by KP »
