Author Topic: "represents" Association for Activity Pa  (Read 5554 times)
qa82
« on: September 18, 2012, 12:06:41 am »
according to the UML standard there is a "represents" association for UML Activity Partitions:
represents : Element [0..1]
An element constraining behaviors invoked by nodes in the partition.
I need this association to model a certain case, however I cannot find this association in EA. Any ideas?
Michael
« Last Edit: September 18, 2012, 12:07:34 am by qa82 »
Re: "represents" Association for Activity Pa
« Reply #1 on: September 18, 2012, 05:27:14 pm »
Isn't that the "Instance Classifier"? (right click Advanced|Instance Classifier)
qa82
« Reply #2 on: September 18, 2012, 10:06:59 pm »
yes, this looks good, however in the dialog that opens I cannot select the correct element. My case is the following:
I have a UML Class that contains two UML parts and one owned behavior as UML Activity. The Activity contains two Activity Partitions and these Partitions represent the two UML Parts. However, I cannot select the parts, they are not shown. With other elements it works.
However... when I try to export it as XMI there is no "represents" attribute set. So obviously the "instance" settings are not equal to the "represents" attribute. Maybe something internal?
Michael
